Can't pass deq because of 2nd o2 sensor Please help
About 6 months ago I bought a 98 civic ex from a friend of a friend (I know stupid idea). The car has a jdm d15b swap with the P2P ecu. A few days ago I went to pass deq and I failed because my 2nd o2 sensor was not working correctly. Upon closer inspection some genius spliced both o2 sensors together so both sensors were not giving correct readings to the ecu. My question is... how do I pass deq like this?
Re: Can't pass deq because of 2nd o2 sensor Please help
Lets put it this way. What can I do to pass the emissions test. My state does not have under the hood visual test. What can I do to the ecu and/or wiring harness to be able to pass it. I really hope its possible... If not I just threw my money away.
I never narc'd on nobody!
Fix the wiring so the primary and secondary O2 sensors are on their own circuits like they're supposed to be.
Before you do that, try running a spark plug defouler and see if that solves your problem. You can get them from your local parts store, and they're cheap.
I cannot wire the 2 o2 sensors seperatly because the ecu only supports 1 sensor... Where do I go from here?
EDIT: The splicing wiring problem is fixed. I know have 1 fully functional o2 sensor but cannot plug in the second to the ecu.
If it's a JDM ECU, they only look for one O2 sensor. Than disconnect the second O2 sensor remove it and thread a plug into the secondary O2 bung.
If it's required for emissions testing, you're kinda screwed
Edit: P2P ecu should be USDM and does read, require 2 O2 sensors
Uh, what? The P2P ECU is the 96-00 EX ECU. If you have a JDM ECU, then their scanner wouldn't even be able to connect to the ECU. If you failed because your O2 sensor wasn't reading properly, then they obviously could connect and communicate with your ECU, which means it isn't JDM, which means that it does in fact support a secondary O2 sensor. You're saying things that don't add up.
As you guys can tell i'm pretty much a complete noob in these kind of things. So what we have figured out is that I have a stock ecu and a jdm d15b. Everone seems to think that I can plug the second o2 sensor right in and it should work?
Follow this link, it's the parts breakdown for a 98 Civic Ex exhaust system.
http://www.hondapartscheap.com/auto-...5-speed-manual
With that said, passenger side floor pan should have a connector, like in the diagram, to connect your secondary O2 sensor
Item #27 is your secondary O2 sensor, connector should be close to the back of the catalytic converter on the passenger side.
Assuming that some half-wit didn't cut the wires, yes, you should be able to plug it in and be fine. If some shade tree mechanic thought it would be a good idea to cut the wires, though, you'll need to run wires for your secondary O2 sensor.
I just took a look at it and both 5 and 6 on the A connector for the sensors are intact and nothing seems to be cut. This is a good sign yes?
Going to look for it now. I haven't tried to find it yet. I just assume the previous owners had SOME common sense.
Fish Twig
Read your OP thread and tell me what ecu you have again.
Last edited by Former User; 03-24-2014 at 05:06 AM. Reason: Don't make anymore insulting comments in tech forums like this: "You're a complete dumb ass." Post edited.
Lol easy with the insults. Everyone has to start somewhere. I know i'm a complete noob but im learning. I have a P2P ecu. Stock ecu for an EX.
Last edited by Former User; 03-24-2014 at 05:07 AM. Reason: Thread clean up - removed Tony's insulting remark.
Fish Twig
Plug the secondary into the cat converter.
Last edited by Former User; 03-24-2014 at 05:20 AM. Reason: Post edited - If want members to be respectful to you, then show them the same courtesy.
I know I'm usually the resident ***, but you need to take a step back man. My assholeishness has a purpose - you just seem to be raging.
Side note: Holy ****, "assholeishness" is actually a word
