99 EM1 Wheel Bearing Question.
i Have a 99 em1 and need to replace a wheel bearing was just woundering if i really need to replace with the ABS bearings as the cost is much higher as aposed to the non abs wheel bearings.
Re: 99 EM1 Wheel Bearing Question.
If your car has abs, then yes you do need the abs bearing. The one side has a magnetic ring that the sensor reads so make sure that side faces in. Use a paper clip or something to identify which side is magnetic. But I don't think em1s have abs. I could be wrong about that.
USDM EM1s have no ABS. I think candian models did, though. If your car has ABS, you need an ABS bearing. Check on rockauto if you're buying an aftermarket bearing.
Fish Twig
Unfortunately, I paid more because I thought was getting the Timken. I could have gotten the Koyo for ~$20 less. Debating whether or not to make an issue out of it.
Am I misinformed that NTN or Timken is the OEM equivalent? Majestic sells NTN @ ~$88. This Timken I purchased was originally $86, on sale for $61 shipped though. Found Koyos all day for $40 shipped.
Fish Twig
You live, you learn. I've made purchasing mistakes before but its because I was in a rush. Sometimes when I order from online oem dealers I look for the cheapest price AFTER shipping is included. Every single one of them have there hits or miss plus it also depends on who is located closer to your location for cheaper shipping.
