valve cover bolt won't tighten
I have a 1993 Honda del Sol SI 1.6 liter I recently changed the valve cover gasket now the 2 outside bolts in the front will not Tighten the bolts are fine I believe it is stripped in the block curious if anybody knew what size tap I need to use to make this repair it is leaking pretty bad I need to get those tight and any suggestions are greatly appreciated
PHANTOM MENACE
Re: valve cover bolt won't tighten
http://www.justanswer.com/uploads/am...6_timing_1.gif
Also, I believe you mean stripped in the head not the block.
Cuong-nutz
04-13-2005 09:39 PM
