98 civic lx front passenger window issue
When I purchased my civic the guy I bought it from told me that the window hadn't worked because of some "Electrical" issue. I've noticed that every other window I use using the master switch dims the vehicles lights when they are on (drawing power) but when I try to roll down the front passenger window it doesn't do that. I've also noticed that when you try rolling down the passenger window with the passenger switch it attempts to roll up but not down... any solutions to this before I throw a bunch of money and frustration into this problem
Re: 98 civic lx front passenger window issue
either regulator or motor is pretty much all that i could recommend.
if you want to test the switch, pull a back door panel off and see if the front switch will roll the other one up or down.
I just swapped the rear passenger switch with the passenger switch and it didn't fix the problem. The switch isnt the problem.
I know it may be tedious but I would try switching motors out. I had similar issue but due to larger problems I ended up replacing the entire door for my fix.
I pulled a window motor from the junkyard a while back and installed it and still no luck. Since it did come from the junkyard there was no guarantee that it wasn't already bad when I bought it. Just making sure... will the rear window motor fit the passenger front window??
I just check the passenger door and some of the wires are showing copper through, I've only checked the passenger side so far.
On that rubber boot there are 2 green objects correct? And what techniques do you recommend for taking that off without damaging anything?
Just pulled the rubber boot away and sure enough you're right again Ron! One wire is broken later today im going to try and connect it back and hopefully it works . The wire that I found broken was blue and yellow.
The wire was the problem!!! Had to use heat shrink to bypass the harness because the wires had broken off inside. Nonetheless everything works!! Window is fully functional again!! Thanks Ron!
einzelherz
08-26-2013 06:41 AM
hondapwr
07-17-2009 05:30 PM
BauleyCivic
05-01-2005 04:42 PM
