Car does not start/ no click sound
Good day,
I am trying to start my car (Civic EG4), but I get no ignition. I also do not hear any clicking sound when I turn the key.
I checked the battery, and it does have power.
Is this maybe because a fuse blew?
Thanks in advance.
Thanks in advance.
Re: Car does not start/ no click sound
Do you have a multimeter?
The starter does not crank the engine with the key in ON(III), right? Does the fuel pump prime? If so, check whether the rubber stopper that presses on the starter switch at the top of the clutch pedal fell out.
Do you have a multimeter? No I don't
The starter does not crank the engine with the key in ON(III), right? Do you mean when I turn the key fully clockwise, I should hear the engine at least try to start? If so, then no...the engine does not start
Does the fuel pump prime? If so, check whether the rubber stopper that presses on the starter switch at the top of the clutch pedal fell out. Not following you on this one, but my vehicle is automatic
Get a multimeter. You can buy one on sale for as little as $4 at Harbor Freight Tools.
Does the starter turn the engine (=crank)?
How did this problem start?
Is the G3 transmission ground wire attached to the chassis and transmission?
Does battery voltage reach the starter motor and starter solenoid connectors?
How did this problem start? Honestly, the problem just started right out of the blue. And I drove the car whole day previiously.
Does battery voltage reach the starter motor and starter solenoid connectors? Checked...and all is good. Engine still not coming on.
since your getting voltage, no click, definitely sounds like starter solenoid.....
if you were at-least getting the click the starter brushes might be bad or seized.. but no click means solenoid...
Sorry for the late reply. To update...I ended up carrying my car to the mechanic (who discovered more issues).
Thanks for your help though
Hondacrf
06-16-2017 04:13 AM
solk1dd
07-23-2007 06:25 PM
