Clutch opinions
Clutch opinions
Hello HT. I'm in the middle of a swap and cant decide on a clutch brand. I'm looking for a daily driver with a little more grab. I've always used ACT clutches but most people i talk to are saying go Exedy. Both are priced comparatively. Any thoughts?
Re: Clutch opinions
Exedy ACT is overkill in most cases Competition clutch is worth looking into also. nothing above a stage one would be needed and even that is overkill imo...
Re: Clutch opinions
The car will be a daily driver /weekend warrior. GSR swapped into a 98 DX hatch. Sorry for leaving out the details. Engine will be stock internally with A/C and P/S.
I never narc'd on nobody!
Re: Clutch opinions
Exedy "stage 1" will give you better responsiveness for track days without sacrificing longevity. I wouldn't be caught dead with an OE clutch on a track. If you're more comfortable with ACT, there's nothing wrong with their SPSS kit for what you'll be doing. I'm personally a fan of Competition Clutch, and for something similar to your setup, I'd go with their stage 2 offering, part number 8026-2100.
Re: Clutch opinions
Exedy OE works just fine on a race track for a mostly stock car....just as an original clutch works well on a mostly stock car. I'm surprised that people still use ACT's awful clutches anymore.
Re: Clutch opinions
I have a CC kit on my h2b and I would def recommend it to my friends. In fact, it was advised by my friend because of his positive experience on his Ap2.
Re: Clutch opinions
LET ME GIVE YOU SOME REALL MAN ADVICE ... don't worry about it .. stage two lightned fly wheel as a package of ebay some Chinese **** for about 150$ you don't need name brand or be worried about too much grab etc... I did stage one and I thought it was just ******* then I went stage 2 for the st daily driver even delivered pizza on and off for years in an urban setting... once you wear that clutch in after 2/3 months youll be just fine with a stage two on the st and you ll be sure to have anough grab on your weekend adventures . also put a short shifter in.. the combination of the three will give you a ferarri type shifting feel where it just falls in and you gotta be a decent driver to where you know your exact shifting points .... it comes naturaly with practice if your running gsr or si tranny on your set up theyre shorter gears and you can up shift in lower load demanding situations and litteraly be crussin in fifth at like 35 lol keep your rpms low and that's it and when you want to romp on it your good to go
Re: Clutch opinions
H-T supports quality and will adjust the consensus as quality of brands change.
Currently, Exedy is considered some of the best quality for the money at this time. There are other quality clutch makers out there but they are usually a bit more expensive and are only required when you start getting into track use or serious horse power situations.
Hopefully you find this information useful.
Cheers
Re: Clutch opinions
Thanks for the overwhelming response and helpful (and some not so helpful) information. Given my situation i felt most comfortable spending money on Exedy.
Man U FTW
Re: Clutch opinions
Exedy gets from me. I ran the Exedy Stage 2 (3 puck cerametallic) for a few years and it was great for a stock block turbo DD. I would imagine their OE replacement to be of the same great quality.
no one wants to hear the truth
Re: Clutch opinions
the stage 4 Six puck lost most of its springs yet, the clutch disc itself had life left in it
