Air Conditioning; Where to start on reviving the A/C?
Here I go again, not finding my specific issue.
Now that I have the mini-me done on my 99 DX hatch it's time to see about getting the A/C back online.
As far as I know everything is still there but the belt to the compressor has been cut. It was like that when we got it, very common for older vehicles around here. People rather not bother with the expense or hassle of properly maintaining the a/c on an aging car and just grimace and bare it during the 2-3 months that a/c is appreciated. Better mileage and power are the excuses most people here use to make them feel better about it as well.
I have no idea what the actual issue was that prompted the PO to cut the belt. Any advice on preliminary diagnosis and repair would be appreciated.
Is there anything I should be careful about? Should I try to get my existing compressor running by hooking up a belt, try to charge it and hope for the best? Maybe get a used unit to mess with or just locate a reconditioned unit right off the bat?
Would it just be better for me to take it to a shop and let them deal with it? I know A/C can be a pain more because of regulations, etc. than actually addressing the problem. If I do end up taking it to a shop should I supply the parts or leave it entirely up to them?
Man U FTW
Re: Air Conditioning; Where to start on reviving the A/C?
If all of the lines are still connected, the pump should be in decent condition. Does it spin freely?? (remember there is a clutch on the pulley)
If so, toss a belt on it, recharge it and see if it still works. As long as the compressor isn't seized, it should be pretty straight-forward
I'm not sure if it spins, clutch or otherwise, it's such a pain to get to. I'll try to get at it later today and see. I can just reach in with a socket to make sure the compressor spins right?
BeatDX I agree with Schister66, before you try recharging it though, you may want to take the car somewhere to have the A/C system completely purged then recharged.
So, I'm guessing that busting my knuckles getting a wrench on the 14mm bolt/nut in the center of the clutch assembly and then busting my knuckles more when it slips off without budging isn't a good sign.
Sounds like the bearing in the rotor pulley is seized, which does not necessarily mean the compressor is bad. The pulley can be replaced.
With the key in ON (II) and the cabin blower turned on, does the condenser fan run and the compressor clutch engage (click) when you press the A/C button?
Fish Twig
You must have some huge hands........I don't have that much room, infact any civic owner, doesn't have much room in there but I manage to take my time and get the job done.
I have seen there are replacement clutch and pulley assemblies available. Would I need a puller or just an impact wrench to get those off?
I couldn't reach it at all from the top. I'd have to move the PS pump to even think about getting there. I had to crank the steering wheel full left and reach up from the bottom while I watched where my wrench was by peering over the top of the fender and wheel well.
Fish Twig
I think its possible to move the p/s pump out of the way to get to where you need to be, it would make things a whole lot easier. I did a complete rebuild, new seals, cleaned the lines, new evap and condensor, new dryer and synthetic oil. Oh also new compressor. All in one day, started early morning and finished around 5pm.
What did you do in regards to evacuating the old refrigerant, purging the lines and recharging?
It's apparently possible to replace the compressor clutch without disconnecting the refrigerant lines if you are able to work in a tight space.
Fish Twig
OH man if its just the clutch, and I have the right tools, will not take me long at all. I think you can rent the a/c compressor clutch tool.
Fish Twig
I plan on moving the PS pump once I get into the thick of it. The question is how thick that is going to be. I'm once again between jobs so I'm trying not to get in any deeper than necessary.
OK, Not getting anything at the connector (red silver) that hooks to the large red wire going to the compressor. Key in ON position, A/C button on with condenser fan running. I swapped the fan and clutch relays with no change, checked all the fuses in the under hood box and the A/C Heat fuse under the dash. All good.
I was hoping so but I was wondering what tony did about the evacuating and purge procedures in his fix.
So you didn't evacuate any residual refrigerant or purge the lines of air before you recharged?
I was thinking of that but wasn't sure which terminals were which and the car has disappeared again. Damn 17 yr old punk kids!
I get voltage to the plug if I jump, none if I have relay in place whether or not I swap the relays between the clutch and the fan. No clutch response but I do get sparking when I touch the jumper wire.
For both jump tests (1-2 and 1-4)?
There's more than one problem.
1) Measure the clutch clearance and Ohm test the coil. See post #9.
2) Reinstall both relays. Unplug ECU connector A. Turn the key to ON(II). Ground pin A17 in the unplugged connector. Do you now measure battery voltage at the red wire of the compressor?
No clutch response
zackn8
08-30-2010 01:23 PM
FSUseminoleEM1
05-22-2009 09:27 AM
