Car won't start after radio istall
Old 03-26-2014, 04:58 PM
theidoctor's Avatar
Default Car won't start after radio istall
So i installed a new stereo myself.... and it works!!!! but my car wont start. it turns. everything works (well kinda), but the car doesnt start. i checked fuses and all are good but i will recheck them when its light outside
it just sounds like its going to start and does that forever! but radio works
i have a full tank of gas too
when i switch back to the old stereo it does the same thing
one thing that could have caused it is i cut the wires while it was all plugged in and i saw a small spark coming from one of the larger black, yellow, red or one of those wires. im not sure if it started then or not. but i know that i replaced fuses afterwards. also my radio is a 15A fuse and i put in a 20A fuse cause i didnt have any other ones....
when i took the radio one out, it still doesnt start. i dont know what to do
98 red honda civic
Old 03-26-2014, 08:46 PM
crazyhouse2011's Avatar
Default Re: Car won't start after radio istall
why does the color matter yet the engine does not?
Old 03-27-2014, 05:35 AM
Hatster89's Avatar
I believe when doing any electrical work it is recommended to disconnect the battery to avoid sticky situations like this. I would go over all your fuses again just to be sure they are ok. I would make sure the radio was grounded properly as well.
Old 03-27-2014, 05:43 AM
AZ_CIVIC's Avatar
For sure check your fuses again and if you have a car alarm make sure you didn't cut any of those wires. If you wiggled any alarm wires out you will get power to everything but the car won't start.
Just throwing ideas out.
Old 03-27-2014, 07:50 AM
theidoctor's Avatar
does the car have some fuel shut off thing for if i mess with it? or how to reset it... i dont even know where it would be located after all these searches
Old 03-27-2014, 09:25 AM
Grape Ape Guy's Avatar
isnt the remote entry in that car through the stock radio? Does the stocker still need to be in dash and connected?
Old 03-27-2014, 10:20 AM
Fish Twig
tony_2018's Avatar
Check fusebox in the engine bay>?
Old 03-27-2014, 11:29 AM
Ej1coupe3's Avatar
I vote fuses too , did you use a wire harness or cute factory wires ?
Old 03-28-2014, 08:34 AM
theidoctor's Avatar
i checked all the fuses... at least the smaller ones. i will see if my friend can help me with the rest. I had harnesses and cut those while it was still connected... hence the spark.
ugh, im so stupid!
hopefully my friend can figure it out. At first it was the ignition coil fuse that went out. the ignition one is a larger one and from looking through the clear top, it looks fine, but i havent unscrewed anything to check.
Old 03-28-2014, 08:35 AM
theidoctor's Avatar
yeap, i put the stock radio together and it still works...
Old 03-28-2014, 09:56 AM
cbaber's Avatar
Check main relay. Check fuses under the hood. Check all fuses under dash again.
Old 03-28-2014, 12:17 PM
you need to do a continuity test on fuses you suspect of being bad.... I have had a few blow and LOOK ok but were actually shot. Little less common but still possible
Old 03-31-2014, 02:29 PM
theidoctor's Avatar
fuses are still being checked. everything else works it just doesnt spark at the ignition coil. we changed ignition coil and ignition control module.
Old 03-31-2014, 03:29 PM
Oh look, I can change this
deschlong's Avatar
This.
Old 04-01-2014, 03:44 PM
theidoctor's Avatar
Well crap. I hate to say this but not really. Car works!!!!!!!
When I was checking fuses the night I asked this, I had take one out and put it in the wrong spot. Apparently I had pulled the fuel pump fuse under the hood.
Now my new problem is getting it to turn off when I take the key out and on when I put the key in. Much simpler I hope.... But that was an expensive radio install!!!!
Old 04-01-2014, 03:52 PM
ej7attack's Avatar
please do research before you do things to your car!
Old 04-01-2014, 04:32 PM
Fish Twig
tony_2018's Avatar
Unfortunately this will have to be dealt with by a mechanic close by. I fear you will probably end up short circuiting more than you think.
Old 04-01-2014, 04:51 PM
theidoctor's Avatar
im gonna get my friends audio store to take care of it eventually.... until then, im happy it all works.
Old 04-07-2014, 12:03 PM
theidoctor's Avatar
update: Got everything working! He said i was getting residual power or something like that. Basically the power from stock radio was still going through to the new head unit which made it stay on for a little longer period and would power off eventually.
He cut wires that i didnt need and rewired everything works as it should.
egcoupe[lsB16]
11
06-27-2010 07:13 PM
kenny707
01-18-2009 05:58 PM
kotton909
05-18-2008 10:44 PM
M2B4
12-19-2006 07:33 AM
ludespeeder
10-11-2002 08:52 PM
Quick Reply: Car won't start after radio istall
