1996 Honda del Sol VTEC - B16A2
I just purchased a 1997 JDM B18C-R for my car. I am reusing the transmission that came in my car from the factory (mates with an OBD2 B16A2). I want to replace the clutch and flywheel. Will I need these designed to fit a 1997 Integra Type-R or designed to fit my 1996 VTEC del Sol?
Please, serious and knowledgeable answers only. Thank you.
Kenny
Kenny
Cool Cool Island Breezes. BOY-EE
Re: 1996 Honda del Sol VTEC - B16A2
Any hydraulic B series civic/integra clutch and flywheel will work.
The clutch that comes with that motor may be good still. The factory ITR clutch is really nice. ITR flywheels are also light weight. So...if all that all comes with...use it.
If you need a new clutch, exedy is a good brand.
Either the Exedy KHC05 or the Exedy stage 1 meant for any 92-01 Civic/Integra B series is a good kit.
You can resurface and reuse your B16 flywheel...find a used ITR one, or buy a good quality light flywheel.
Lol...that's a really bad idea. But hey....sometimes you ask for advice and then just do whatever anyway.
Amazon.com: Exedy Stage 1 Clutch and Lightweight Flywheel Kit for 1994-2001 Acura Integra 1.8L DOHC / 1999-2000 Honda Civic Si 1.6L DOHC: Automotive
Your prices were a slight bit off, unless you can find it cheaper.
Your amazon post was for a stage 1 with a chromoly flywheel. $499 seems a bit high even for that.
The OE replacement kit (equivalent to stock) is about $110 at rockauto. It will work perfectly on your ITR motor.
The stage1 by itself is like $250ish on ebay or other tuning shops.
Exedy flywheels are about $200 by themselves. Because they're lightened chromoly flywheels.
Alternatively, you can find a stock (used) ITR flywheel for about $100. This is an excellent option. Or maybe your motor will already come with one. Resurface it. Reuse it. It's a nice flywheel.
Or reuse your stock flywheel for free. Plus the resurface cost ($40ish).
The flywheel at O'reiley's will most likely weigh a couple more LBS than stock. It'll be over priced, just like their clutches.
If you want a cheapo "stock replacement" flywheel, check ebay or rock auto. Same thing as O'reiley...but less $$. Why would you do this, though?
I never narc'd on nobody!
http://www.ebay.com/itm/221165309567...84.m1439.l2649
What do you guys think about this? I appreciate all the help and information. Really.
$112 -no flywheel
http://www.ebay.com/itm/Exedy-KHC05-Clutch-Kit/231075509373?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D21235%26meid%3D5927704311129818005%26pid%3D100005%26prg%3D9374%26rk%3D1%26rkt%3D6%26sd%3D261419755017&rt=nc
4contactpatches
07-01-2017 11:59 AM
onegreedy
11
11-08-2005 10:22 PM
