if the check engine light is on does it mean vtec will not work?
dont know what codes im throwing but i think there for the 02 sensors.. but will this make vtec not work?
thanks in advanced
thanks in advanced
alright... cause i have a b16a with itr cams... and im sure vtec will be noticable but i dont notice it at all... i need to wire the ks and the o2 sensors and hopefully itll work
Re: (chuniepatuni)
At this point the last thing you need to worry about is "mad vtec yo".
Find your problem and fix your car! Get a book and do some reading.
Re: (sauceja)
engine light will not always keep VTEC from engaging. VTEC will still engage without a knock sensor in the engine at all. but if your running your engine without O2 sensors , lol , which is hilarious , im sure that will dampen the cars spirit , lol.
Re: (egmatt93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egmatt93 »</TD></TR><TR><TD CLASS="quote">i dont think so im running a cel right now and my vtec is crackin just fine...</TD></TR></TABLE>
me to
me to
Re: (siblue99ek)
vtec needs five things to engage. The correct oil pressure, the correct water temp, VSS reading speed, a load on the motor, and the correct RPM's. If you have a CEL that directly effects any one of those, than you will not have vtec. So having a knock code, or 02 code does not effect vtec. Now it will however effect other things.
2wheelhunter
08-15-2006 08:11 AM
