How to install a chip for a p72 ecu
I just recently bought a chip for my ecu and dont know of no one to install it, and i also lost the instructions for it, and i would like to install it my self, but i would need the instructions, CAN ANY1 HELP MEEE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
H-T White Ops
if you bought a "chip" to give you 11ty billion HP and increase your gas mileage by 30% while raising your rev limit to 10,000 and getting rid of your speed limiter, throw the damn thing away. You're wasting your money and run a good chance of blowing your **** up if you run it.
Re: (that one doood)
what's it matter if it's from ebay. all the chips are they same burned image of someone's modded rom image...
http://www.pgmfi.org/twiki/bin...pping
bottom of the page is directions on what to mod...
Re: (dem0nk1d)
about 30 dollars worth of parts to chip that ecu properly. including i think its 28 pin socket and rom , someone correct me if im wrong im still learning.
Re: (cranny)
30 bucks worth of parts... No! Try like 10 bucks for everything.... Including caps, resistors, 28 pin ziff socket, and the small ziff socket. I can buy blank UV about 2.00 bucks each.
Re: (dem0nk1d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dem0nk1d »</TD></TR><TR><TD CLASS="quote">30 bucks worth of parts... No! Try like 10 bucks for everything.... Including caps, resistors, 28 pin ziff socket, and the small ziff socket. I can buy blank UV about 2.00 bucks each. </TD></TR></TABLE>
Not even $10 with a EEPROM.
The most expensive part will be the ZIF. The low profile Aries ZIFs go for about $6. You can chip an ECU with no ZIF for about $2 including an EEPROM chip.
I Have an STD
13
09-30-2003 10:18 PM
