Best LCA's to get for an EK?
I wonder wich LCA's should i get and if i should get any at all. I'll get adjustable suspension and sway bar with the brace, i thought of replacing the LCA's while i'm at it. Should i do it, wich one should i get? I remember seeing once some that had a ball joint in them, what about those?
Anyway does a replacment make sense and wich one would make the most sense?
HT White Ops
Re: (egmatt89)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egmatt89 »</TD></TR><TR><TD CLASS="quote">can u buy aftermarket front lcas, because my right front is shot no bushing metal on metal FTL</TD></TR></TABLE>
Yes, but it's way cheaper to source one from a junkyard.
http://www.car-parts.com
Re: (Eran)
just go buy some new bushings at honda it will be cheaper!
unless you want to be a baller and buy the omni front control arms.
for the rears the function7 are the best that ive seen and worked with!
Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">^not if its 96-00
I have function7 for swaybar adjustments</TD></TR></TABLE>
omni is making that design now
Function sells their own sets on ebay, for prices lower than than other online shops that sell them...
The different holes make the bar act "stiffer" than it would normally (or softer, depending on the hole)
Thing is, you MUST use their endlinks with the lca's (or other aftermarket) because the stock endlinks are too short (they wont tell you this unless you specifically ask....which is retarded)
Just becaust omni makes them, doesnt mean its the same lca.
I doubt omni will use urethane bushings, that function does - they'll stick to that crappy rubber garbage
Re: (pdiggitydogg)
Their endlinks are like $50 or something, do you know the name of the seller on ebay that is selling the real deal, not to get succered in for a low price and end up buying crap.
http://stores.ebay.com/Function7-Engineering
they give you a discount on the endlinks if you buy the lca's
Re: Best LCA's to get for an EK? (chad)
contact davidr on here i bought mine from his store and sells them cheaper than anyone i seen. also he is a registerd function7 dealer i belive! They r not cheap but worth every penny.
projectzum is the website i belive.
Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">http://stores.ebay.com/Function7-Engineering
they give you a discount on the endlinks if you buy the lca's</TD></TR></TABLE>
We give a discounted price as long as you have a valid serial number so we can cross reference the order (i.e. the serial number will qualify you for the discount pricing).
Give us a shout if you need the linkages of if you need the HT discount code.
http://store.function-7.com
Regards
-AT
Regards
-AT
Re: Best LCA's to get for an EK? (wicked2night)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad »</TD></TR><TR><TD CLASS="quote">http://www.picperformance.com</TD></TR></TABLE>
I just ordered a set from PIC. Customer service was wonderful, I have never dealt with someone who was willing to answer question after question. Plus the quality of their product is top notch.
Charlie Moua
06-09-2004 12:41 PM
