Swap help vx into Dx.
Ok, I know I am most-likely going to get flames over this but I need a little assistance. I tried searching but since this probably isn't done very often I cant find anything Ok, here goes, I have a hx hatch that has a blown engine, I also just happen to have a vx engine and ecu. what wires do I need to run besides the vtec wire for the vx engine? I just need cheap semi-temp fix for now. If there is a thread already about this can someone point me the right way?
Oh somebody's done it before.
I'm confused as **** though.
Title:
"Swap help vx into Dx."
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CHK4TIX »</TD></TR><TR><TD CLASS="quote">I have a hx hatch that has a blown engine, I also just happen to have a vx engine and ecu.</TD></TR></TABLE>
What are you asking? VX into HX or VX into DX?
I suppose it doesn't really matter. Assuming they're both OBD-I, you have the ECU 'n all everything should just be plug 'n play. I wouldn't even wire up the VTEC, just get ur hands on a VX harness, you have the ECU, everything'll plug right up.
Though if you want to wire it instead of just getting a VX harness (which you can get at a junkyard for mad cheap btw) all you should need to wire up the VTEC.
I'ma holla at bense, he knows his way around the D15Z1, he can tell you anything else I may have (and probably) missed.
Title:
Re: (Syndacate)
I ment vx into a dx, I guess my typing skills got the best of me. Thanks that is what I wanted to know. I think I might have an extra vx harness laying around as well. I just need to get this car on the road. Thanks again for the info
Modified by CHK4TIX at 8:32 AM 12/4/2006
Turbomadness07
04-22-2004 03:51 PM
