Wierd "Knocking" from front suspension
Old 12-02-2006, 09:29 AM
HT White Ops
Eran's Avatar
Default Wierd "Knocking" from front suspension
Ok, whenever I accelerate from a stop at a low rate of speed, or decelerate from a stop at a medimum -> high rate of speed, I get an wierd knocking noise, usually 1-4 times, from both front corners. I also sometimes get it when not creeping over speedbumps/railroad tracks/etc. My car is not slammed, nor do I have a front lower tie bar, so nothing is hitting the road. It's not my lower ball joints, or my upper A-arm ball joints ....
Help?
PS - 97 Civic CX, B18B1 swap, Tokico Illuminas, H&R Sport Springs, Stock Mounts.
Modified by Eran at 11:36 AM 12/2/2006
Old 12-02-2006, 10:36 AM
HT White Ops
Eran's Avatar
bump
Old 12-02-2006, 10:48 AM
egmatt93's Avatar
Default Re: (Eran)
u check ur lca bushings my **** does it too completley missing the bushing
Old 12-02-2006, 10:52 AM
HT White Ops
Eran's Avatar
Default Re: (egmatt89)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egmatt89 &raquo;</TD></TR><TR><TD CLASS="quote">u check ur lca bushings my **** does it too completley missing the bushing </TD></TR></TABLE>
Well, that could explain it. I know one of my LCA's is fucked, and I have a replacement for it. I'll have to check the other one once I get my garage and can install the replacement.
Old 12-02-2006, 10:56 AM
egmatt93's Avatar
Default Re: (Eran)
the way i checked was jack the side up thats making the sound and push and pull on the wheel if it moves more then it should check where the lca meets and see if the busing is fked or gone hope i helped
ventturei27's Avatar
also check your upper ball joints, if everything is fine it could be your hub
Old 12-03-2006, 12:49 PM
HT White Ops
Eran's Avatar
Any more suggestions would be appreciated.
Old 12-03-2006, 02:19 PM
YoungKadafi's Avatar
mine is doing that....this is what i have found to fix the problems.....both of my axles had a rip in the boot, and my wheel lugs werent on tight enough.
Sure you may think the axles only make noise when turning, i found that to be a lie, cause the problem went away once i change em......
Old 12-03-2006, 02:20 PM
HT White Ops
Eran's Avatar
Default Re: (YoungKadafi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YoungKadafi &raquo;</TD></TR><TR><TD CLASS="quote">mine is doing that....this is what i have found to fix the problems.....both of my axles had a rip in the boot, and my wheel lugs werent on tight enough.
My axles are only 40K old.
Old 12-03-2006, 02:28 PM
sorry, just a sugestion....however my drivers side axle was only 2 weeks old
Old 12-03-2006, 02:29 PM
swifty4u's Avatar
Default Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">My axles are only 40K old.</TD></TR></TABLE>
mine are like 5k old and are bad already
Old 12-03-2006, 02:37 PM
HT White Ops
Eran's Avatar
The thing is, this has been going on for a while, it's just progressively gotten worse. I even changed my axles about 40K ago, and it still made the same noise.
Old 12-03-2006, 02:49 PM
swifty4u's Avatar
Default Re: (Eran)
Check your LCA bushings..the one that bolts to the underbody of mine is almost completely gone, and its causing a weird vibration, sound, and my axles to bind up.
MechEng
02-18-2015 05:58 PM
garyc17
06-27-2007 02:48 AM
jdmh22luda
06-26-2007 12:44 PM
beaterman
12-01-2005 03:35 AM
IntEGNYC
12-10-2003 06:58 AM
Quick Reply: Wierd "Knocking" from front suspension
