need help with swap got a few problems...
Ive got a 96 hx converted to obd1 with a conversion harness running a p28 ecu. It had a swap already done with a d16z6 (done very shitty and half ***). The motor was blown when I got it so I bought a d16y8 and began my swap yesterday. The motor is in but I decided to use the intake mani off the z6, will this have any problems? also they hacked the harness and put obd1 distributor plugs and with the y8 I have to run an obd2 dizzy... so if I just put an obd2 plug back on the harness with the new distributor will it just plug in and work with the obd1 ecu? also there is a sensor that i broke right above the oil filter. Is this the knock sensor? If im not mistaken and I shouldnt need this being that Im obd1 or will I?
i also need i diagram for how to hook an fmu up on a honda and i need info fast as i will not have access to a comuputer when i go to the warehouse to work on the car. all input would be very appreciatted
boobstedminime
06-06-2012 09:04 AM
efrunner09
09-20-2009 10:24 AM
