Steering shakes
Steering shakes
Hi, on the highway(above 100 km/h) the steering wheel shakes pretty good. I'm pretty sure the wheels are balanced, the tie rods were replaced not too long ago as well as the ball joints.
What could be throwing it off?
Thanks!
Thanks!
Re: Steering shakes (Malakai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Malakai »</TD></TR><TR><TD CLASS="quote">I'm pretty sure the wheels are balanced,
Thanks!</TD></TR></TABLE>
Get it done, and make sure.
Also, have them double check the alignment, and the runout in the wheel itself.
well the car was fine yesterday. Nothing has changed when i went to work this morning. Then at lunch going home it shakes really good.
Re: (Malakai)
Do you have aftermarket wheels?
Mine, and a friends did the same thing and he got hub rings i think they were called and it went away.
Its a ring you put in the back of your wheel of over the axle hub.
Ours would shake when we got up to about 60 or so.
well ima put it up on jack stands tom and take a look. hopefully its not major.
And the steering is loose. But the tie rods have been replaced like 5 months ago. What could make it loose?
Re: (USDMej1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDMej1 »</TD></TR><TR><TD CLASS="quote">if slush freezes it will throw them off.</TD></TR></TABLE>
What he said, and if you have stone stuck in the tread.
Re: (Malakai)
my brotehrs 98 civic hx automatic did the same thing, all we did was replaced the front rotors and brake pads and changed his tranny fluids and the car ran almost new again. the rattling stopped.
k brakes it is. i wanted to get some new rotors anyways.
What do u guys think drilled or slotted?
Im thinking slotted but just want some opinions?
Re: (Nova_Dust)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nova_Dust »</TD></TR><TR><TD CLASS="quote">I thought a warp rotor won't vibrate unless you apply brake? I swapped a pair of used ones and everything was find until I braked.
Just a thought.</TD></TR></TABLE>
Yeah x2 it shouldn't shake until you brake...unless your pistons are bad and they are stuck closed, and your rotors are warped...I've had my brakes stuck applied and it sucked!
trooper0641
18
12-25-2003 05:26 PM
