building b18c1 block?
wondering what internals i should use to build a n/a gsr block. like what kinds of rods and pistons etc... im planning on a poor mans type r build so i will be using b16a2 head
Re: building b18c1 block? (CeeJay16)
Whats your goals and how much you willing to spend? If you want to do a basic just use the GSR internals with Type R or CTR pistons.
Re: building b18c1 block? (Luserkid)
i want to try for 200 whp at the wheels.. im going to be working for a while to afford everything and im in no hurry to get this done so just looking for the best parts quality wise
ctr pistons, skunk or buddy club cams, upgrade the valve springs, lighter valves, pnp, better intake mani, better header, that'll get you started....there's tons of posts about people's builds on honda-tech. chances are you can find somethin and get an idea of what you need in order to reach ur 200whp mark
been there done that
Re: (Itzmy91Teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Itzmy91Teg »</TD></TR><TR><TD CLASS="quote">is it <u>not</u> true that the ctr pistons make the highest compression ratio? </TD></TR></TABLE>
it's true. but what good is 12-13:1cr when you have to pull a ton of timing just to get the engine from pinging running on pump gas? you can make the same if not more power by running 11:1cr and full timing. plus the ctr's high dome doesnt promote good flame travel.
Re: (that one doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by that one doood »</TD></TR><TR><TD CLASS="quote">it's true. but what good is 12-13:1cr when you have to pull a ton of timing just to get the engine from pinging running on pump gas? you can make the same if not more power by running 11:1cr and full timing. plus the ctr's high dome doesnt promote good flame travel.</TD></TR></TABLE>
true..
true..
Re: (Itzmy91Teg)
Check out the all motor forum. There's a lot of different setups hitting 200whp. a couple of threads with dynos, setups, and 1/4 times. A lot of good info
Re: (whal3_p3nis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whal3_p3nis »</TD></TR><TR><TD CLASS="quote">Check out the all motor forum. There's a lot of different setups hitting 200whp. a couple of threads with dynos, setups, and 1/4 times. A lot of good info </TD></TR></TABLE>
x 2
x 2
godluvstegs
24
10-28-2011 02:16 PM
Man_EK9
02-10-2008 11:52 AM
ALLMOTOR CRX
18
06-22-2007 01:39 AM
