Radiator fan stop working! Help?
Would that be a sign that the radiadtor is going out? Is there any other reason for that radiator fan to stop functioning? I need to fix this ASAP!!
Re: Radiator fan stop working! Help? (Nameless Warrior)
relay is under hood... hmm think its the top right one, fuse is also under hood... but the top to the box should say what is what. also check if fan is getting power. does the rad have any leaks?
apply power and a ground straight to the plug for the radiator fan.. if it goes on you know your problem is elsewhere. Another thing you can do is unplug the connector for the CTS and jump it with a paperclip. if the fan goes on you need a sensor.
