94 civic, I loose all of my radio presets when I turn off car
Old 12-08-2006, 02:43 PM
94civicoupe's Avatar
Default 94 civic, I loose all of my radio presets when I turn off car
When I turn off my car, I loose all of my radio presets and my clock goes to 1:00. Can anyone help? I'm not really sure where to look....
Thanks
Mitch
Old 12-08-2006, 02:44 PM
adictionbass's Avatar
Default Re: 94 civic, I loose all of my radio presets when I turn off car (94civicoupe)
is it a stock or aftermarket radio?
Old 12-08-2006, 02:49 PM
Default Re: 94 civic, I loose all of my radio presets when I turn off car (adictionbass)
It is an aftermarket, but I also loose the clock.....
Old 12-08-2006, 02:50 PM
tha_badguy's Avatar
did you do the wiring to it yourself
you most likely didnt wire in the constant power to the deck
Old 12-08-2006, 02:51 PM
Default Re: (tha_badguy)
get the wiring diagram and pull the radio out. There is an ignition power and a constant power. You probably only have the ignition one hooked up
what about the clock though....the one in the dash, not the radio...
Old 12-08-2006, 03:02 PM
Kista20's Avatar
Default Re: (94civicoupe)
have you checked all the fuses?
Old 12-08-2006, 03:04 PM
Yes, but fuses would only make them not work.....right? I dont think a fuse would make something malfunction, you know? I did check them though, and they are all good...
Thanks
Mitch
Old 12-08-2006, 03:06 PM
jfruauff's Avatar
Switch the orange or red and yellow wires. You mixed them up.
Old 12-08-2006, 03:57 PM
Kista20's Avatar
well if you had a bad fuse on a "memory" wire it would loose all it's settings when it's turned off.
Old 12-08-2006, 04:38 PM
White95SiHB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94civicoupe &raquo;</TD></TR><TR><TD CLASS="quote">When I turn off my car, I loose all of my radio presets and my clock goes to 1:00. Can anyone help? I'm not really sure where to look....
Thanks
Mitch</TD></TR></TABLE>
Before you pull your radio out, go and pop the hood of your car. Open up the fuse box (passenger side of the car, by the battery) and check the "backup" fuse. It's possible it might be blown.
Old 12-08-2006, 05:03 PM
HiProfile's Avatar
Default Re: 94 civic, I loose all of my radio presets when I turn off car (White95SiHB)
AFAIK, the clock has a capacitor or something in it. I bet its very dim while idling, and almost doesn't light up when you press it w/ign off. I bought a coupe with the whole radio/lighter/clock circuit FUBAR'd, does the same thing. I'd had other pressing issues with the car, so I don't know exactly what it is. For whatever reason though, both out cars aren't supplying the constant 12v though that circuit.
Old 12-08-2006, 06:08 PM
junior40er's Avatar
Default Re: 94 civic, I loose all of my radio presets when I turn off car )
okay here is your problem. No he does not have a blown fuse because if he did his radio would not turn on. The radio has a constant (yellow) that is always powered to hold memory/settings and a ignition (red) to turn radio on when ignition is on the ON position. In order for the radio to turn on BOTH yellow and red have to be powered. So either of two things:
1) both yellow and red are wired to ignition or together on same ignition power source, causing it to turn on when ignition on BUT lose memory when reset since there is no constant power.
2) yellow is wired to ignition (which should be constant) and red is wired to constant (which should be ignition)causing it to provide 12V when ignition on but again losing both power source when ignition off. This will also cause your radio to intermit when playing full power. (since ignition source is low amperage)
Old 12-08-2006, 07:56 PM
platinumx6's Avatar
Default Re: 94 civic, I loose all of my radio presets when I turn off car ) (junior40er)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by junior40er &raquo;</TD></TR><TR><TD CLASS="quote">okay here is your problem. No he does not have a blown fuse because if he did his radio would not turn on. The radio has a constant (yellow) that is always powered to hold memory/settings and a ignition (red) to turn radio on when ignition is on the ON position. In order for the radio to turn on BOTH yellow and red have to be powered. So either of two things:
2) yellow is wired to ignition (which should be constant) and red is wired to constant (which should be ignition)causing it to provide 12V when ignition on but again losing both power source when ignition off. This will also cause your radio to intermit when playing full power. (since ignition source is low amperage)</TD></TR></TABLE>
Old 12-09-2006, 11:15 AM
Default Re: 94 civic, I loose all of my radio presets when I turn off car ) (platinumx6)
Fixed. Constant was not hooked up at all....it was only hooked up to 12v ignition. Still dont know about the clock though...
Old 12-09-2006, 01:33 PM
junior40er's Avatar
Default Re: 94 civic, I loose all of my radio presets when I turn off car ) (94civicoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94civicoupe &raquo;</TD></TR><TR><TD CLASS="quote">Fixed. Constant was not hooked up at all....it was only hooked up to 12v ignition. </TD></TR></TABLE>
thats not a surprise.
so whats exactly the deal with the clock?
Old 12-09-2006, 03:11 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by junior40er &raquo;</TD></TR><TR><TD CLASS="quote"> No he does not have a blown fuse because if he did his radio would not turn on. </TD></TR></TABLE>
I was thinking the same thing since my radio also didn't turn on when the backup fuse was blown. When I replaced that fuse the radio AND THE CLOCK started working. I figured it wouldn't hurt to have him check the backup fuse since the clock is still not working.
If the fuse is not blown but the clock is still not working, can't the clock be wired to the radio's constant wire?
Old 12-09-2006, 03:13 PM
MassScene's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by junior40er &raquo;</TD></TR><TR><TD CLASS="quote">okay here is your problem. No he does not have a blown fuse because if he did his radio would not turn on.</TD></TR></TABLE>
you dont know what your talking about.
check the back up fuse. its responsible for supplying a small amount of current to the radio for the use of saving settings. if it is blown there will be no memory.
Old 12-10-2006, 06:51 AM
Default Re: 94 civic, I loose all of my radio presets when I turn off car ) (MassScene)
Fixed the clock, too. Back-up fuse was blown thanks alot guys
Mitch
Old 12-10-2006, 03:12 PM
junior40er's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MassScene &raquo;</TD></TR><TR><TD CLASS="quote">
tell me how much experience you have in car electronics. particular in audio/video security. Watch out what you say before you open your mouth.
Old 12-10-2006, 06:21 PM
MassScene's Avatar
I am not here to critique your ability in car electronics, wiring, ect. However judging by your incorrect response "its impossible its a fuse....blah blah blah....the radio wouldnt work at all...blah blah blah....", it would appear you DONT know what you are talking about in this particular situation. However it is quite possible you are a very good car audio/electronics guy so dont take my comment as me discrediting your ability because that wasnt my intent.
by they way I didnt "open my mouth", i used my fingers!
Old 12-11-2006, 05:48 AM
junior40er's Avatar
by they way I didnt "open my mouth", i used my fingers! </TD></TR></TABLE>
I knew you where gonna bust out with that. lol
Old 12-11-2006, 05:51 AM
junior40er's Avatar
as a experiment. go under your hood and pull your back up fuse. you will notice that your radio will NOT turn on.
Its been 2 years since I worked in a shop as a installer but Im pretty sure im correct on that. I worked in avionics now so thats my new expertise.
Old 12-11-2006, 06:10 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by junior40er &raquo;</TD></TR><TR><TD CLASS="quote">as a experiment. go under your hood and pull your back up fuse. you will notice that your radio will NOT turn on.
Its been 2 years since I worked in a shop as a installer but Im pretty sure im correct on that. I worked in avionics now so thats my new expertise. </TD></TR></TABLE>
That is incorrect. because my radio worked fine, but my clock just would not remember the time. the back-up fuse was blown the whole time...
Old 12-11-2006, 06:16 AM
Techy's Avatar
hmmm that's odd cause when my back up fuse blew in my EJ1 the radio didn't work and the clock was dim and couldn't hold time. It was an aftermarket CD player too. It also caused my SRS light to come on too.
Quick Reply: 94 civic, I loose all of my radio presets when I turn off car
