-=[ADD TO STICKY]=- .:'Civic Maintenance FAQ':.
This thread is intended to cover regular maintenance items for civics beyond the basics. Many of these items may not be thoroughly stressed or explained in the helms manual. If there are any topics that you would like added, please send me the info and it can be added to the list.
Pulling code on a Check Engine Light (CEL)
http://www.c-speedracing.com/faq/06.php
http://members.spboards.com/vi...cteam
List of CEL and trouble codes
http://tech.hybridgarage.com/tech/codes.html
Bad Idle Troubleshooting
http://www.ef-honda.com/ben/Badidle.php
Flushing Transmission Fluid
http://www.c-speedracing.com/h...d.php
Flushing/Changing Coolant
http://www.d-series.org/forums...13144
Cleaning your Idle Air Control Valve (IACV)
http://www.superhonda.com/foru...44463
Changing your primary O2 sensor
http://www.superhonda.com/foru...30863
Adjusting your Ignition Timing
http://www.sohchonda.com/artic...=0005
http://www.c-speedracing.com/h...g.php
Helms Idle Reset/Adjustment Procedure (96-00 Civic)
http://www.redpepperracing.com....html
D-Series Timing Belt Replacement
http://my.prostreetonline.com/...?t=70
http://www.hondatuningmagazine..._belt/
D-Series/SOHC Valve Adjustment Procedure
http://www.angelfire.com/biz7/....html
B-Series/DOHC Valve Adjustment Procedure
http://www.c-speedracing.com/h...t.php
Special Tool for B-Series Valve Adjustment
http://www.toolcraze.com/Merch...=spec
http://matcotools.com/Catalog/...29534
Performing a Compression Check
http://www.georgiazclub.com/ti...t.htm
http://www.hazone.com/hb18ccomptest.htm
http://www.sohchonda.com/ipw-w...=5275
http://www.superhonda.com/foru...24194
Performing a Leakdown Test
http://www.superhonda.com/foru...57985
http://www.c-speedracing.com/h...n.php
Other Resources/References :
http://www.superhonda.com/foru...53746
http://www.c-speedracing.com/howto.php
Modified by dem0nk1d at 12:50 AM 12/9/2006
Modified by dem0nk1d at 12:55 AM 12/9/2006
Modified by dem0nk1d at 1:42 AM 12/9/2006
Modified by dem0nk1d at 10:03 AM 12/9/2006
Re: -=[ADD TO STICKY]=- .:'Civic Maintenance FAQ':. (dem0nk1d)
good links
doesnt work tho
doesnt work tho
Re: (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">That's some good info there, definitely got my vote for putting it up as a sticky.</TD></TR></TABLE>
i agree, some links are broken but still god DIY guide.
-PinoyCivic
-PinoyCivic
Re: (Syndacate)
Re: -=[ADD TO STICKY]=- .:'Civic Maintenance FAQ':. (sleeperrex)
A thread like this was already created a long time ago...
https://honda-tech.com/zerothread?id=642479
Re: -=[ADD TO STICKY]=- .:'Civic Maintenance FAQ':. (sicones)
Some info applies differently, but hey... i am trying to just help...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones »</TD></TR><TR><TD CLASS="quote">A thread like this was already created a long time ago...
https://honda-tech.com/zerothread?id=642479</TD></TR></TABLE>
No kidding, nothing that isnt already there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dem0nk1d »</TD></TR><TR><TD CLASS="quote">Some info applies differently, but hey... i am trying to just help...</TD></TR></TABLE>
for you.
for you.
yes it is...its a sticky the one u put...but some of those links in their the pics dont work and these ones are really in depth. very helpful imo
