purge kit???
When you use nitrous oxide,some of it stays in the lines so the next time you need to use it,you "purge" it(get rid of it).This gives your car a better "hit" when you inject it into the engine.Them N20 that stays in your lines oxidize or something like that and if you just inject it like that then your speed burst won't be as strong as if you had purged the N20 out of the lines
* B A N N E D *
Re: (dwigman)
you want liquid nitrous in your lines when you spray otherwise the cooling effect of the nitrous is nullified gaining almost nothing
you vent the gasoues nitrous into the atmosphere so when you hit that trigger, the liquid immediatley turns into gas cooling air down hus making power
