head lights killing my radio and also turn signals???
* B A N N E D *
ok this morning when i turned my headlights on i noticed that my radio shut off and then turned on again. also when my light are on and I use my signal it kills my stereo and then it turns on again, but i use my signal with lights off this does not happen. what could this be ??????? also if my head lights are on are on the emergency lights don't kill my radio and the signals do ????????????? thank you all. somebody had this problem few days go...I searched and didn't find anything? so thank for helping me.
thats kind of an odd problem, the only thing i could sugest would be check all the ground point for the head light and signel circuits. it could just be a bad ground. if that doesn't turn up anything check the wiring harness coming from the head light switch and see if any of the wiring is maybe touching other wires. it's not to much info but it might help.
* B A N N E D *
Re: (HONDA300)
thanx for trying, good points ...but the shitt turned out to be the white wire on the alt. was loose i hope this helps anyone with this same problem.
Jazzy Jeff 978
05-10-2008 09:51 PM
