NEED HELP FAST.. CANT GET 93 CIVIC DX GUAGE BEZEL OR CLUSTER OUT
i cant get the black bezel the goes over top the cluster to come off of the dash. we took out the 2 screws on top and one screw behind the hazard swithc but its still really tight an just wants to crack?? am i missing a screw or is there some technique to take it out
Re: NEED HELP FAST.. CANT GET 93 CIVIC DX GUAGE BEZEL OR CLUSTER OUT (hondatuner020)
Yeah, it'll still be in there pretty tight even without the screws but don't be afraid of breaking it, just pry that bitch out of there.
Re: (ifIexplode)
put your hand in the hole for the hazard switch and pull the passenger side out slowly.. then right above the steering wheel pry up easily and 2 clips will come out of the bottom.. the when its loose on the passenger side pull the driver side out and towards the passenger side at the same time.. ti will take a little prying on this side..
hope this helps
hope this helps
theres also a bolt behind where the clock should be..... then yea use the flathead to pop it up and out
suspendedHatch
12-28-2005 04:58 PM
hypnotic
06-13-2003 10:44 PM
zer0zer0 TypeR
03-05-2003 04:24 AM
