brake pad question...
if my brake pad is loose in the caliper... does this mean my piston is frozen? or will a brake pad get so worn out that at a certain point, it can't extend far enough to press the pad into the disk? is there supposed to be a clip at the bottom which holds it or something? the pad can be moved by hand a good 1/8 of an inch from left to right.
i found how too's on how to change brake pads, but all of them have expired pictures and i couldn't see what i wanted to see...
any help is appreciated!
thanks
-simon
thanks
-simon
Re: brake pad question... (nonvtec92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvtec92 »</TD></TR><TR><TD CLASS="quote"> is there supposed to be a clip at the bottom which holds it </TD></TR></TABLE>
or are u on about the squeeler. it should be on the back pad. jst a little bit of metal to tell u wen ur pads are worn out.
uneek360
04-13-2007 07:19 PM
