radiator hoses???? b18c into 00 ex...any factor hoses that are direct fit??
just wondering if i there are any oem hoses that will fit at the radiator and the engine with the correct sizes at both ends of the hose??? plese let me know what hoses will work best if there arnt any that will fit perfect...i know there are a lot of posts about this but couldnt find any specific enough ones...thanks
Re: radiator hoses???? b18c into 00 ex...any factor hoses that are direct fit?? (ricekiller1)
im not sure if this is the same for the 00 civic...but for my 93 hatch, i know that if the motor has a B16A head or Type R, use 94 Del Sol DOHC VTEC.
For engines with B18C head, use 94 GSR
and the lower radiator hose from a 94 del Sol DOHC VTEC.
but thats for 5th gen civic...
u might want to look into 99-00 SI (EM1) hoses...maybe those work
this place sucks...its MOSTLY(not all) NOOBS!!!!!!!!!!!!!!!
HT White Ops
The OEM B18C hoses will not fit properly over the stock EX radiator. The EX radiator has an outer diameter of 1 1/8" and the B18C hoses have an inner diameter of 1 1/4".
You need a Del Sol VTEC radiator or a 99-00 Civic Si Radiator.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ricekiller1 »</TD></TR><TR><TD CLASS="quote">this place sucks...its MOSTLY(not all) NOOBS!!!!!!!!!!!!!!!</TD></TR></TABLE>
Remind me not to help you anymore. You've got a poor attitude.
Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">The OEM B18C hoses will not fit properly over the stock EX radiator. The EX radiator has an outer diameter of 1 1/8" and the B18C hoses have an inner diameter of 1 1/4".
Remind me not to help you anymore. You've got a poor attitude. </TD></TR></TABLE>
or you can just use hose clamps
HT White Ops
Re: (egsleepercivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egsleepercivic »</TD></TR><TR><TD CLASS="quote">
or you can just use hose clamps</TD></TR></TABLE>
It depends. I used some hardcore t-clamps on mine, and two different sets of worm clamps, and the top hose still leaked. I just replaced the radiator and it worked fine. Also gives you that nice dual core instead of the single core SOHC radiator.
Shoot0
11-20-2010 04:28 PM
ricekiller1
03-20-2007 12:54 PM
Littlegreend15
03-24-2005 06:18 AM
jbsadler
07-02-2001 05:03 PM
