driveshaft problem
driveshaft problem
ok i have a 95 ex coupe with a ls swap my drive shaft keeps popping out. is there a longer one i can use preferbly oem cause cant afford nothing aftermarket rite now. its the ls drivshaft im using rite now. i was wonderin if i used one from a d16 would that work. and its on the passenger side
Re: driveshaft problem (JDMstatus95)
Are you sure you have LS driveshafts in there? You should not need a longer one. Make sure it's in all the way and there is no damage anywhere.
yhea when i put the cv axle in the tranny and tighten the axle nut it just pulls the cv axle right back out the tranny. it wont stay in place.
