advancing the timing on a stock engine... any cons?
i dont have a timing light right now, so are there any downsides to running at fully advanced?
Re: (allricedout)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allricedout »</TD></TR><TR><TD CLASS="quote">detonation? on a stock motor that will hardly happen, so can someone else reply who has had experience wiith doing this?</TD></TR></TABLE>
wrong. it can happen on ANY stock motor. even more so if you run **** gas
you'll wear out your plugs faster. but as long as you only adjust a little bit...then you'll be fine. 1-2 degree's. some people say more
but using the search wouldnt be too bad either
i already searched and there was just a ton of worthless threads........
so are you saying i would have to run 91 octane if i didnt want detonation.... im not sure if thats an acurate assumption becuase with the low compression on a STOCK d15 i dont think it would detonate.
then try it...
you run a pretty big risk running fully advanced
you made another thread, saying to got a timing gun (dont know why that needed another thread)...just do it right and be done with it
Re: (allricedout)
I moved my dist. a little bit adavnced because my car was feeling sluggish when I had it directly in the center. It felt a lot better after I advanced it a little. But make sure you have it checked with a timing light. As for detonation, running 87 octane isn't bad for your d series. It's only bad if you have high compression like me (b16), I have to use 91 octane or higher or else I will get detonation.
Re: (EM1_ChRiS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EM1_ChRiS »</TD></TR><TR><TD CLASS="quote">I moved my dist. a little bit adavnced because my car was feeling sluggish when I had it directly in the center. It felt a lot better after I advanced it a little. But make sure you have it checked with a timing light. As for detonation, running 87 octane isn't bad for your d series. It's only bad if you have high compression like me (b16), I have to use 91 octane or higher or else I will get detonation.</TD></TR></TABLE>
as far as i can remember timing for a B16 is 17 +-2 degrees right?..... so when you advanced it how many degrees were u at?
Re: (allricedout)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allricedout »</TD></TR><TR><TD CLASS="quote">as far as i can remember timing for a B16 is 17 +-2 degrees right?..... so when you advanced it how many degrees were u at?</TD></TR></TABLE>
I don't remember but I think stock for a b16 is 16 + or - 2 degrees. I dont think I went more than that.
Flr Power
12-19-2004 10:44 PM
X2BOARD
10
04-08-2004 05:18 AM
