Cluster lights flicker once Ignition placed in ON position
I have a friend that once you turn the key to ON the cluster lights flicker and you can hear the relay flicker. This also caused the clock light to not turn on any more. Did a search but nothing matched this problem. Checked all fuses and they were good. Thinking it could be the altenator but car wasnt started and everything else still works. Battery doesnt drain and car still starts like a champ. What could be the problem. Thanks in advance. Could it possible be the radio short circuted and cause this problem. Cos from what I was told this never happend till it was installed. I checked the wiring in back and everything was perfect. Radio Harness was used and non of the wires were sliced. Everything was installed properly.
Lambo123
08-04-2013 02:11 PM
wes7side5o
03-22-2007 05:08 PM
snuggles
04-07-2005 10:58 PM
