D16Z6 CAM IN D16Y8?
D16Z6 CAM IN D16Y8?
Hey guys and girls, Im new here. But anyways, I am wondering if a d16z6 cam will work without any modifications in a d16y8 head. I have an aftermarket cam in my z6 right now and im getting a 1.6 EL soon, so im hoping I can put the cam in it.
Go Tigers!
Re: D16Z6 CAM IN D16Y8? (. a d a m)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by . a d a m »</TD></TR><TR><TD CLASS="quote">No, I'm pretty sure you can't do that.</TD></TR></TABLE>
you can do it
http://www.d-series.org/forums...41363
good luck
you can do it
good luck
Re: D16Z6 CAM IN D16Y8? (Bense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense »</TD></TR><TR><TD CLASS="quote">
you can do it
good luck </TD></TR></TABLE>
Well, technicallyy speaking, no he CANNOT do that. Did you read his original post?
"I am wondering if a d16z6 cam will work without any modifications in a d16y8 head"
Without modifications is the key term here. An advanced cam gear would be a modification, wouldn't it? So, technically, no.. You cannot just drop the cam in and expect it to work correctly. You can however rig it to work using an adjustable cam gear.
you can do it
Re: D16Z6 CAM IN D16Y8? (lluks_844)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lluks_844 »</TD></TR><TR><TD CLASS="quote">well if hes changing the cam he would need to redo the timing so it would just be almost no modification
If by "Redo" the timing you mean install an adjustable cam gear to compensate for the difference in the keyway.... sure! Thats all I am saying.
Go Tigers!
Did you guys read the link that I provided?
Z6 cam, y8 head? Which cam gear do you use?
heheheh
What does he set base timing to? 12 or 16 btdc?
what's the dizzy index in the z6 cam set to?
heheheheh
heheheh
heheheheh
