Need help lowering
Re: (solbrothers)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solbrothers »</TD></TR><TR><TD CLASS="quote">check the suspension forum. but i think you need to hold the shaft with an allen wrench and turn the nut with an open end wrench. but watch out for your eyes. that **** is gonna want to shoot off like a fucken rocket </TD></TR></TABLE>
that's why there's a spring compressor
Re: (longuyen88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by longuyen88 »</TD></TR><TR><TD CLASS="quote">
that's why there's a spring compressor </TD></TR></TABLE>
expletive that, that takes too long.
Just aim it at the wall, about a foot away, and when you get close to the end of the threads, set it down on the ground and stomp the wrench with your foot.
Re: (slowEGchris)
We've used an impact and actually stripped the inside of the nut. We've also used a spring compressor and tried to put the entire piece back in and trying it again. Nothing seems to be working. I'll check out the suspension thread though.
Re: (99CivicGirl)
Go to autozone and get a spring compressor. When you return it, they give you all of your money back. If you try to do it without a compressor, it's under a lot of tension and could be bad news.
Re: (okdc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by okdc2 »</TD></TR><TR><TD CLASS="quote">Go to autozone and get a spring compressor. When you return it, they give you all of your money back. If you try to do it without a compressor, it's under a lot of tension and could be bad news.</TD></TR></TABLE>
agreed
i used a spring compressor and then put an allen key in the top of the shock and had no problem backing out the nut
agreed
Re: (solbrothers)
Alrighty. LIke said, we stripped the inside of the nut. NOne the less, we used a little heat and a lot of "Dad" power and got it to come off. Down side, when I replace my struts I'll have to cut that strut off, it's not going anywhere. Thanks for the help guys!!! I LOVE MY SI !:D
neilff
05-30-2003 12:03 PM
