a/c belt wtf?
Re: a/c belt wtf? (immajackuup)
I'm not even sure what you're asking? The A/C belt goes around the crank, compressor, and tension pulley... There is nothing else... What is causing you a problem?
im trying to take the belt out but i just found out the motor mount is in the way.
so if i take the motor mount off do i have to put a jack under the motor for support or the other 2 motor mount should hold it?
Re: (immajackuup)
Geez...
Just unbolt the tq mount from the chassis and loosen the driver side upper mount studs so the engine is lowered around 1/2" or so... Thats all.
well i got it done. took the two bolt off from the bottom mount that is connect to the a/c bracket and slid the belt in.
didn't need to take off the major motor mounts
BluTeggy
05-29-2009 04:59 PM
PYITR821
06-25-2002 11:30 PM
