help with o2 sensor b18c1 into 97 civic
ok im throwing a cel for primary o2 sensors my obd2a gsr ecu is mested up so i gotta use my friends ex computer do I need civic ex o2 sensor or b18c1 ones???
thanks in advance
thanks in advance
Re: (HitF8)
yea cause what is wierd is the fact that i changed that main o2 sensor like 3 months ago but i got the one for the b18c1 and i need to pass emissions and that is the only code i am throwing other then that i alreay connected the snd o2 sensor staight off the ecu
Re: (wrenchez81)
it should I even counted the pins unless I was suppose to cut the 2nd o2 sensor wire from the ecu staight to the o2 ??? cause what all I did was tap into the wires but you see I plan on just wiring my 1st o2 sensor straight from the ECU if I cant still get that code to go away though but all I know is im tired of avoiding cops due to my tags being expired
jdm1980
03-10-2008 08:13 AM
