Couple questions about B18B1 in EG
YESSSS, Im finally swapping in a b-series! My friend did the same swap in his hatch (i have a sedan btw), and he used his d-series shift linkage and he said it worked fine. Is he full of **** or will it really work? I have the linkage for the b anyways, but i just wanted to know. Also, as far as I know the stock mounts will work, only if you have the alluminum driverside mount that comes in EXs. Is this true also? I also have all the mounts from the b-series, but again im just curious. Hubs? I have DC integra hubs but i have heard stock civic ones will work fine. Again, just curious. If theres anything else i need to know, PLEASE LET ME KNOW. Im rippin my d out this weekend because im tired of my friends cars being faster than mine! Thanks!
Re: Couple questions about B18B1 in EG (slo_hatch)
True, but i just wanted a more experienced opinion on what works and what doesnt work
Re: Couple questions about B18B1 in EG (InTheLBC20)
well when i was gonna do my b series swap...they told me that i needed all the b series stuff...motor, tranny, mounts, shift linkage, ecu, and sometimes a wiring harness. so im not 100% sure...but im pretty sure the mounts will not work and the linkage do not either.
Seagull Management
Former Moderator
Small clarification:
The two front lower anti-roll mounts that bolt to the undersides of the frame rails needs to be 92-95 Civic as the Integra ones do not sit flush with the frame rails. These are the horseshoe shaped mounts.
Also are you trying to keep A/C? If you are that will dictate what a/c bracket is used. If you want a/c use either a 97 CR-V or 94-97 Del Sol VTEC a/c bracket. If not a/c then use the Integra bracket.
Re: Couple questions about B18B1 in EG (B18C5-EH2)
Former Moderator
Those brackets let you use your stock a/c compressor, right?
donvito#1
04-17-2008 07:36 PM
