rear disk question
What he's maybe thinking is that you don't have the wrong proportioning valve, which is most likely correct. IIRC when you swap to rear disc from drum you need to replace the proportioning valve with the one from the disk car. Also, it is a good idea to swap the fronts to the disks from the donor vehicle also, but is not necessary. Only reason I say this is because you will have more braking force in the rear than before, and under certain specific conditions you may be able to lock the rear up.
Your best bet is to look for Unbrakeable's thread on this in the Archive. Everything you wanted to know about brakes on a Honda/Acura vehicle is in there including swaps, sizes, and the parts you need.
Re: (The_Honda_Guy)
so when doing the integra rear disk conversion into the eg i would need the integra proportioning valve + master cylinder + booster = proper working brakes right?
Re: (wrenchez81)
You don't have to have the MC and booster if your only doing the rear disc conversion. If your hatch is an EG then you have a 13/16's MC which is crappy. Get a new one from a 91 Civic EX Sedan. It is a 15/16's MC and it bolts right up with no modification.
Remember that the size is always stamped on the side of the MC. The integra MC and booster will require a bending of brake lines because they don't line up the same. However, all 94-01 ABS Integra's have a 1" MC and it is the best. Also, if you are going with the Integra MC and booster, get a 98-01, the fitting and flare size from your hatch is the same and no modification is required other then bending the lines. There is lots of info on this.......FAQ's! Also search, I have posted this info before, with pics.
Modified by iliv2xlr8 at 3:01 PM 11/13/2008
Seagull Management
Re: (oramac_eg)
Scenario 1
stock front brakes, stock master cylinder, '92 Si proportioning valve, integra or civic rear disks.
Why it works? Because this is exactly how the '92 Si's are set up. Non abs, 13/16 master cylinder, different Si proportioning valve and rear discs.
Scenario 2
Integra front brakes, Integra brake booster and master cylinder combo a non abs integra, or stock booster and '91 EX master cylinder. non abs integra proportioning valve, civic or integra rear discs.
Why it works? Because this is how the non abs integras are set up. Non abs, 15/16s or 7/8 master cylinder, 4040 proportioning valve, larger front rotors and calipers, rear discs.
just to add to it all, i went with 95 teg rear disk (YES THEY WERE ABS) i just removed all that ****. 95 teg 1" master cylinder and booster and 4040 prop valve (NON ABS) and 95 teg from knuckles rotors and calipers (WERE ABS) again removed abs ****. you need the knuckles cause the dx civic wont fit the rotors and calipers.
the eg came with ex front brakes witch should the same as integra i have a cx model
what year integra didnt come with abs?
how can i tell the abs brakes apart from the non abs?
Seagull Management
Re: (oramac_eg)
Re: (oramac_eg)
Upgrading the whole lot is a good idea but not strictly necessary, im still running my old proportioning valve even though i have rear discs and have had no problems whatsoever
Re: (gstewart27)
And they will operate "fine". The difference is at the limit. Drum brakes require more hydraulic pressure then disc brakes. As such, the proportioning valve is different from drum to disc.
If you run the drum valve with rear disc you will probably not see a problem with normal breaking. But when you have to brake hard because someone pulled in front of you, the rears will lock and the fronts will not get the appropriate pressure they need.
Manufacturers do things for a reason. Cars are our hobbies, but it comes a point to where its a safety issue. When my wife is in the car, I want to know that my setup is doing exactly what it should be, if not better.
I am doing this same swap on my 93 dx hatch. The prop valve was $40 shipped from a person here on hondatech. Just post in the WTB, do it right, and feel that peace of mind.
Re: (iliv2xlr8)
Seagull Management
Re: (gstewart27)
Originally Posted by gstewart27
Thats not true - locked my front brakes a few times but never the backs, people told the same thing as you're saying before i upgraded my brakes but i cant get the backs to lock at all, the calipers are so small i doubt they have the power to lock the wheels tbh
Re: (gstewart27)
Not true. You dont NEED to change your master cylinder or proportioning valve or the servo, rear discs work fine with the originals.
I was in the same boat with my old hatch. I hate it when people say you NEED to change prop valve and master cylinder when doing a rear conversion.
Kyo Babic
03-04-2003 11:27 AM
