93 ej2 GSR redlines at 6500 RPM instead of 8200 RPM.
Alright i have a obd1 GSR w/ a skunk2 intake manifold and throttle body. it is not throwing any CEL's, VTEC engages properly and the car runs hard BUT it redlines at 6500 RPM instead of 8200 RPM. Please some help me . Thanks in advance
Modified by jeffnerette at 5:02 PM 11/13/2008
Re: 93 ej2 GSR redlines at 6500 RPM instead of 8200 RPM. (Sr420Det)
its been doing since i did the swap about 6 months ago but i didnt think much of it because i was running a stock p28 automatic but i replace the ecu with a stock p72 and its still doing it.
Re: (jeffnerette)
I still would try another ecu, is your gsr a auto? Shouldnt it throw a code if its not a auto or theres a separate control module for the auto.
Re: (Sr420Det)
Cool Cool Island Breezes. BOY-EE
Re: (jeffnerette)
Originally Posted by jeffnerette
I don't have another ecu to try. And my GSR is manual and the ecu I don't know. But it not throwing any CEL.
Why were you using a P28 automatic on the GSR swap?
Re: (B serious)
Originally Posted by B serious
Take it somewhere that has ECUs laying around so they can try a known good one into your car.
although, i dont think it would throw a code if its the wrong computer
Re: (sol2hatch)
like sol2hatch said it the only ecu I had. And it was auto because I did the GSR swap/auto to manual conversion at the same time. My CEL works because it threw code 41 for o2 sensor and I changed it and in went out but still recline at 6500 RPM. I'm running out of ideas.
Re: 93 ej2 GSR redlines at 6500 RPM instead of 8200 RPM. (gabydman2003)
Originally Posted by gabydman2003
check what ecu do you have, i know the older ones dont rev as high as the obd1
GDD Member
Is the ECU JDM or USDM? Grab your stock ECU and compare it side to side, if it's JDM, the JDM ECU will be a little bit smaller than a USDM ECU. Auto GSRs were only available in the Honda Integra SiR-G, so if you've got a USDM ECU, then it can't possibly be automatic.
Also, I don't think the Auto ECU has a lower redline, I had an Auto LS/VTEC DB7 with JDM P30 AUTO ECU and it would usually shift around 7800rpm at WOT, but I never had the Auto P72, so I can't say for sure.
Usually a low redline is an indication of a timing belt one tooth off or a bad distributor.
Re: (slomofo)
GDD Member
Check your timing belt first, it's easiest. Pop your valve cover off, turn the engine to TDC and look to see if the marks line up. Swap distributors with someone else to see if that's the problem.
Edit: On the distributor part, it's usually the coil that causes the problem. Your stock SOHC coil should be interchangeable if you don't have another distributor to swap over for a quick test.
