My Do-It-Yourself D16Y7 swapped to D16Y8 in my EK
Old 11-13-2008, 04:09 PM
chickenwing's Avatar
Default My Do-It-Yourself D16Y7 swapped to D16Y8 and many upgrades in my EK
Pics are worth a million words.
Out came the D16Y7
engine out
added some upgraded motor mounts
my built up D16Y8 will have a new home
preparation of the wiring.
the oem plugs
you know what they are
plucked terminals from this connector
soldering and heat shrink
pass wires through this hole
modification at the ECM
wiring in the engine bay
motor finished
needs a brake upgrade from 9 inch to 10 inch WINTER integra spindles
pads
rear suspension upgrade
this broken bolt head gave me some grief.
i drilled it out
Modified by chickenwing at 5:27 PM 11/13/2008
Modified by chickenwing at 5:28 PM 11/13/2008
Old 11-13-2008, 04:14 PM
sageuvagony's Avatar
Default Re: My Do-It-Yourself D16Y7 swapped to D16Y8 in my EK (chickenwing)
Originally Posted by chickenwing
engine without motor
LOL... Good work though!
Old 11-13-2008, 04:15 PM
Default Re: My Do-It-Yourself D16Y7 swapped to D16Y8 in my EK (sageuvagony)
fixed lol!
Old 11-14-2008, 01:57 PM
Xxplosive's Avatar
Default Re: My Do-It-Yourself D16Y7 swapped to D16Y8 and many upgrades in my EK (chickenwing)
lots of pic but dang u should of clean ur bay up when ur motor was out. there so much rust on hatch where do u live
Old 11-14-2008, 02:45 PM
halocore's Avatar
Default Re: My Do-It-Yourself D16Y7 swapped to D16Y8 and many upgrades in my EK (Xxplosive)
looks like it's an easy plug and play, or should i say drop
Old 11-14-2008, 02:48 PM
95vxtealhatch's Avatar
Your gonna hate those motor mounts, and you'll eventually take them out. Mark my words.
Old 11-14-2008, 03:05 PM
turbojdmhatch's Avatar
Default Re: (95vxtealhatch)
the blox lca bushings usually dont last long
Old 11-14-2008, 05:01 PM
Default Re: (turbojdmhatch)
I'm not too picky about grease since it will prevent rust there.
yes very easy as long as you got all the correct parts. Wiring was easier than anticipated.
Nah, I like the motor mounts and i can feel the motor does not move much.
That is only if you do not tighten the bolts when the arms loaded.
Old 11-14-2008, 05:25 PM
kp
kp's Avatar
Default Re: (chickenwing)
Look pretty good. My only suggestion is that you should apply heat to the whole outside (360 degrees) of the shrink tubes when doing wiring, it looks like you only blasted it with heat on one side.
Old 11-14-2008, 06:02 PM
reaction360's Avatar
Default Re: (kp)
nice build. is the car turbo'd? i thought i saw an intercooler in there. And all that rust would just **** me off! I'm glad cars don't rust up like that here on the west coast. I am however really surprised at how easy you got those rear lower control arm bolts out. they usually rust n break off inside those arms.
Old 11-14-2008, 08:18 PM
EK tommy's Avatar
Default Re: (reaction360)
I've never seen that valve cover before.
Old 11-14-2008, 08:25 PM
Default Re: (EK tommy)
I was thinkin the same thing. its cool
Old 11-15-2008, 03:12 AM
Yes I did blast the heat shrink 360 degrees all around.
Good eye to pick out the intercooler. We have the worst winters here which you have to come and experience yourselves to understand why cars starts to rust in 5 years. Yes those bolts came off but one of the rear lca bolt broke off and required some drilling to get off.
Well there is always a first for everything.
This is an OEM 1.6 VTEC cover for the Y8.
got myself a bigger capacity rad too
Modified by chickenwing at 4:58 AM 11/15/2008
Old 11-15-2008, 04:11 AM
yoitsmelaz's Avatar
looks good
Old 11-16-2008, 05:25 AM
Default Re: (yoitsmelaz)
Originally Posted by yoitsmelaz
looks good
thanks
either you do it correctly or you don't do it at all.
hafaadaiteg
04-08-2008 07:05 PM
aznboi_2
07-10-2007 11:14 PM
rexman
11-14-2006 06:41 AM
Bense
01-11-2006 05:50 PM
dirtyapes
12
07-01-2004 08:58 PM
Quick Reply: My Do-It-Yourself D16Y7 swapped to D16Y8 in my EK
