h22 eg runs then dies
i have a 95 civic dx with h22 swap using dx harness ive don all the wiring stretched all the wires and it ran just wouldnt drive good kept sputtering till i got on it. then i got 02 sensor and ran the vtec wires to the ecu and now it starts then dies and idles jumpy im also running a p28 ecu and i dont hav the plug to check the check engine light its jus not there i looked everywhere and cant find it the only things i dont hav hooked up are egr,knock sensor and secondary butterflies someone help
Re: h22 eg runs then dies (iwanttokillgod)
anyone else wanna help me that knows what there talking about? p28 ecu is better cuz u dont need egr or the butterfly crap
Re: h22 eg runs then dies (tfarol)
make sure you have good ground wire connections. my h22 eg had loose ground wire @ the thermostat housing and did some crazy idle and die stuff to. just an idea.
Re: h22 eg runs then dies (nikko_SOHC)
yah ill run through the grounds again an by the way to the smart guy about the p28 it is chipped you f*****G retard and even if it wasnt it still run it jus run lean if u drove normal it would be fine do some swaps first then open your mouth
Re: h22 eg runs then dies (hatchback13sec)
