Can't find way to check engine light NEED HELP
Old 11-14-2008, 06:09 AM
MonKK's Avatar
Default Can't find way to check engine light NEED HELP
I got a h22 in my civic EK 97. Recently my CEL just came on. I took it to autozone/oreily to check for the code but it said link error and they didnt know why. I try getting the code from the plug under the cluster but it didnt flash any light. How am I suppose to check the code for my light. ANY HELP PLZ.
Old 11-14-2008, 06:14 AM
davefromPA's Avatar
Default Re: Can't find way to check engine light NEED HELP (MonKK)
what ecu are you running? reason i ask is because if the ecu is obd1 the autozone scanner will not work.
Old 11-14-2008, 06:15 AM
slowex98's Avatar
stock ecu obd2a
Old 11-14-2008, 06:33 AM
00b20vtecoupe's Avatar
Default Re: Can't find way to check engine light NEED HELP (slowex98)
you can do the trick, insert a wire into one of the plugs on the ecu and watch the cel flash and count the number on it. someone can let you know where the plug is on ur h22 ecu. then look the code up. i think long blinks r 10 and short r 1's.
Old 11-15-2008, 12:22 PM
MonKK's Avatar
I'm running the p13 ecu chipped. I already try the plug flashing light. It didnt flash. Also I have a jumper harness
Any other way to cheap my code?
hunter fitch
Engine Management and Tuning
02-01-2019 11:12 AM
92DAB16A
09-14-2012 07:14 PM
jayjay
06-04-2007 08:01 PM
crxaddikt
12-01-2003 09:23 AM
RacerXintegra2k
08-13-2002 09:15 PM
Quick Reply: Can't find way to check engine light NEED HELP
