Zero Clutch Pedal Pressure?
Hey everyone,
So a few days ago, I pulled my z6 out to fix a bunch of damage my broken crank pulley caused. Anyways, this morning I put it back in and now there is absolutely zero clutch pedal pressure. I'm not even sure how I would be able to bleed the system if the pedal falls all the way to the floor. Any ideas on what's causing this and what I can do to remedy it?
Re: Zero Clutch Pedal Pressure?
bleed it.. get a friend and bleed it.
https://honda-tech.com/forums/acura-integra-type-r-8/correct-way-bleed-clutch-577567/
if that's not the problem, look for leaking around the master cylinder.. and if there's no signs or leaking and your fluid is full and bled.. take the slave off and examine it, check the seals on it, make sure its not leaking.
https://honda-tech.com/forums/showthread.php?t=577567
Odd problem, but turns out the slave cylinder wasn't pressing outwards.....replaced it, bled it, problem solved.
Thanks for the advice!
