b20b swap help please i just want it in!
I recently bought a whole 1996 integra with a jdm b20b swap in it. I want to swap it into my 1996 civic hx because the body of the integra is in bad shape. i just bought the distributor conversion and I have been looking for the right mounts forever. I bought all 1999-2000 si mounts for it and realized that the top drivers side mount does fit my car, but the bolt pattern is different. The bolt pattern is off of a 1996 integra but I can't find the mount with that pattern that fits my car! please help me it has been a month that I have been looking.
Re: b20b swap help please i just want it in!
i've done that and still come up dry. it says its the right mount to fit a b or d series but i can tell just from looking at them that it wont fit the bolt pattern of the motor.
I think you need to replace the engine mount BRACKET on the side of the engine with the 99-00SI one, not just the mount IIRC?
You only need to parts to correctly bolt this in your car.
1. Driver side cast iron mount that bolts to the block for a 99-00 Civic Si
2. Rear T bracket for a 99-00 Si
The upper trans mount and bracket, rear mount, driver side bracket and rubber mount, and torque mounts from the D series all work. You'll need to re use the actual torque mount brackets that bolt to the engine and trans off of the Integra.
impr323
08-05-2007 12:17 PM
00WhiteEKy
06-22-2003 08:54 AM
