95 Civic A/C fit 00 w/ B-series Civic???
Im sure this has been covered guys but I searched like crazy and have gotten any results. Im trying to put A/C on my 00 Civic with GSR swap. I basically need everything.. lines, condensor, compresor, etc.. Now the thing is that my friend has the complete system from a 95 Civic coupe and wanted to see if the lines and everything would fit? Im almost sure the compressor and condensor will fit just need the compressor bracket from a b-series but will the a/c lines fit? I would really appreciate all the help.. THANKS!!!!!
Re: 95 Civic A/C fit 00 w/ B-series Civic???
Did the car ever have A/C?
The compressor will only mount up to that block with a del sol b16 bracket or crv b20 bracket.
As far as the lines go, you will probably have to make some bends as the chassis' are different.
If the car came with ac, use the ac system with the car. the only thing you will have to change is the mount for the compressor to the motor, as said above when using the civic compressor, you need either the del sol (dohc) or CRV bracket. Im using the CRV bracket because it was only ~$60 new from the dealer and all the del sol brackets are goin for ~$90 used.
freakin_eLRoD
06-29-2004 10:13 AM
lazyguy
06-09-2003 10:33 AM
hatchdrvr
21
07-18-2002 04:33 AM
