d16y7 in a 95 civic lx
Old 06-12-2009, 08:10 PM
Jamezvtec's Avatar
Default d16y7 in a 95 civic lx
can someone tell me what all need cuz we done swapped it today and its not runnin right and its the only car i have got to drive......do i need to use the 98 intake or the 95 and which harness do i nee to be using cuz we r useing the 95 right now and i aint sure if thats what wrong or not
Old 06-12-2009, 08:59 PM
jake 92eg d16z6's Avatar
Default Re: d16y7 in a 95 civic lx
go over all your wiring in the car and what ecu are you running ?
Old 06-13-2009, 05:20 AM
Jamezvtec's Avatar
we r using the the ecu out of the 95 .....cuz the plugs were diff. and the d16y7 was a automatic car and mines a 5 speed
Old 06-13-2009, 05:47 AM
RyanA's Avatar
Did you retain the Y7 distributor base and swap the guts from your 92-95 into it?
Old 06-13-2009, 05:52 AM
civic_driver's Avatar
You have to use the wiring harness, sensors and ECU from the d16y7 if you want it to run right. Also, you might need stuff like the dizzy and alternator, etc.
Old 06-13-2009, 01:18 PM
Seagull Management
94EG8's Avatar
Don't have to, D15B7/D15B8 distributors use the same case/bolt pattern as the D16Y7/D16Y8 distributors. Simply reuse the old D15B7 distributor
No. Retain the original D15B7 intake, exhaust manifold, sensors, alternator distributor, injectors etc. The D16Y8s have weird timing issues when you try to run them with an OBD1 ECU, but so far as I know D16Y7s run ok with a stock OBD1 P06 ECU.
Old 06-14-2009, 11:14 AM
ya you have to run the right ecu.
Old 06-14-2009, 07:09 PM
Jamezvtec's Avatar
well thanx i think we got it runnin right now we changed the intakes and stuff over and its running better now...but still not much power.....but i guess its stock thats y
Chefkik
11-18-2014 06:13 PM
offshore
01-10-2012 04:35 PM
stocker2shocker91
08-29-2005 07:01 PM
Quick Reply: d16y7 in a 95 civic lx
