identify the image! help!
my car is making a noise in front suspension. so i jacked the car up and moved the tire back and forth. and it seems that the noise is comming from this part here. but idk what it is. if anyone can tell me. and does it look bad?
Re: identify the image! help!
inner tie rod... u need a inner tie rod tool(rent from autozone pepboys ect.) to remove(but can be remove with right size wrench) easy to replace takes 10 mins good idea to replace both inner and outer tie rod... and u will need a wheel alignment when ur done
This look bad? Cuz idk if that is whats actually causing the problem/the cracking noise in my front suspension.
