HEATER NOT WORKING
Old 07-02-2011, 08:39 PM
pmp
pmp's Avatar
Default HEATER NOT WORKING
1998 CIVIC EX, THE HEAT IN THE CAR DOES NOT WORK AT ALL. IT JUST BLOWS COLD. THE COOLANT WAS LOW A FEW DAYS AGO AND I FILLED IT UP. ANY SOLUTIONS? ALSO NEW THERMOSTAT AND COOLANT FLUSH ABOUT 2-3 MONTHS AGO.
Old 07-02-2011, 08:43 PM
dk=gsr's Avatar
Default Re: HEATER NOT WORKING
check your coolant again.
Old 07-02-2011, 08:44 PM
pmp
pmp's Avatar
CHECK IT COLD OR HOT
Old 07-02-2011, 09:00 PM
dk=gsr's Avatar
cold. when pouring the coolant down your radiator, squeeze your radiator hoses to make sure it fills up your motor.
Old 07-02-2011, 09:04 PM
Ronnoc74's Avatar
https://honda-tech.com/forums/showpo...79&postcount=3
Try what the diagram says. Start at #8 since you've flushed the system recently. Also park on an incline while you do it so all the bubbles in the system go towards the radiator and can escape the system.
Old 07-02-2011, 09:09 PM
pmp
pmp's Avatar
well its not overheating so im guessing all the coolant is circulatiing but ill check the hoses in the morning
Old 07-02-2011, 09:10 PM
pmp
pmp's Avatar
there is no bleed bolt on my car it bleeds its self
Old 07-03-2011, 04:55 AM
pmp
pmp's Avatar
its full
Old 07-03-2011, 05:13 AM
The Grumpiest
grumblemarc's Avatar
Did you try checking the cable IN the cabin?
Old 07-03-2011, 06:21 AM
pmp
pmp's Avatar
not yet
Old 07-03-2011, 06:30 AM
The Grumpiest
What are you waiting for?
Old 07-03-2011, 07:12 AM
frankenghia's Avatar
move the cold/hot lever on the climate control to cold and then look under the hood against the firewall. Note the position of the heater valve. Now move the lever to hot and note the position of the valve again. Should be opposite direction of the first reading. I had this happen on a 94 civic and I ended up bleeding the system with the radiator cap off and a funnel wedged tightly into the radiator, heater on hot, heater fan off. I filled the funnel up just enough so that it was an inch or two full. Let the car run enough so the fan kicks on twice. Squeeze the hose abunch of times. Remove funnel and excess fluid and hopefully this helps some.... Good Luck!!!!
B18c1vicrx
05-13-2009 01:01 PM
corince06
06-11-2008 12:48 PM
EM2ner
Honda Civic (2001 - 2005)
17
01-14-2008 06:23 PM
drumsy
09-12-2002 07:14 AM
Quick Reply: HEATER NOT WORKING
