help!! misfire at full throttle!
hi guys im new to HT. i already know most people nag and nag "hey noob theres a search button". i searched and cant find a topic to my specific problem. i have a 95 ex coupe with a jdm d15b block and a z6 head. the problem started when i spun a rod in my z6 block. a friend of mine helped me swap the block with the d15b i bought for cheap and when we got it back together it would start cutting out and sputtering once it hit 3k at anything more then half throttle. we are stummped as to what it is.
Map, tps, dizzy, injectors, ecu, vtec solenoid, and FPR have been swapped with ones from a fully running car. the fuel filter and air filter are new, new plugs and wires, its in perfect time (even had double checked at a shop). im just starting to run out of ideas. any help would be appriciated. i cant take only being able to rev out at half throttle!
Re: help!! misfire at full throttle!
Map an tps are not flipped. Already checked that. And I personally didn't check the compression but the shop I took it to that double checked the timing also checked the tps and vacuum lines
he checked the compression on all cyliders and said that it was ok. hes looked over a couple things and connot see what wrong either
anybody ideas would b great. the only thing that i havent changed was the fuel pump. it has a walbro 255 in it so maybe its just giving the car too much fuel or something. im not sure but damn near every sensor has been swapped
update* i recently pinched the fuel line going from the fuel filter to the rail and it started revving to 4.5k now so it has to be fuel related. i swapped in a stack fuel pump and ditched to walbro 255 but that changed nothing. im thinking about getting a wideband and seeing what my afr
fyjimo_jr
02-04-2015 10:33 AM
tacorunner87
14
01-03-2009 09:05 PM
IMPORTMyth01
12
11-27-2006 05:44 AM
