Slow moving power windows
ok so all my windows such as front pass front driver and sunroof all lack power they are super slow especially my sun roof i sometimes have to help it close or open i thought maybe it was just a battery issue so i replaced the battery but that wasnt the problem. i have two other ideas as to what it could be:
altenator (but it is recharging my battery fine thats kinda why i wanna lean away from that)
or the motors for the windows themselves but all three at the same time is kinda suspicious
was wondering what other things it might possibly be
thanks
thanks
Re: lack of power to all windows
Thread title edited. Spray some silicone lubricant into the window glass rubber side channels.
yea i just picked some silicone up today actually lol i used some on my old 2000 civic and it helped a lil but i will check for blown fuses or if im not getting enough power through out the wires and will spray the silicone and will get back at ya guys
Unless you spray an excess of the lubricant into the channels, the lubricant will not be visible since only the non-visible edges of the glass buried into the channels contacts the lubricant.
Re: Slow moving power windows
sometimes it could me the motor on the regulator. Try taking out the regulator and seeing if there is a lot of gunk in the motor. If ther is clean it out that should help. Aswell you could replace the regulator.
Replace your Window Channel seals. Lubing them is only a temporary bandaid and makes a mess of your glass. New, they are lined with a felt on the inside that the glass glides on.. As they get old and dry out, the felt falls/wears off and exposes rubber.. The rubber (like your tires on the road) will grip the glass, slowing your windows down.. I have to do this to my 95 Civ.. If you ask nicely, The dealer can give you about 20% off list which puts you kinda close to internet prices (within about $10) and usually you can get them next day and support local business.
