NEED HELP ASAP!!!!! SEARCHED, NO LUCK!!
I just got a EG CX for dirt cheap, has a motor, NO HARNESS. I start a new job next week I HAVE to have this car running, the ONLY harness I have is an OBD2 Harness, now I know some plugs won't match up but is there ANYTHING I can do from a wiring standpoint to make this **** work?????????? I have ZERO gwap to buy a OBD1 harness so please, Throw it at me, I don't care how towering a job it is, if it's wiring I can do it My other swaps are no longer Street legal, roll cages and putting out way over 700hp, can't use em for a commute like this, PLEASE! PLEASE!!!...HELP!!!
Re: NEED HELP ASAP!!!!! SEARCHED, NO LUCK!!
alot of connectors are different i belive...
Have to rewire:
-alternator connector
-distributor connector
- connector to the strut tower most likely different
Should be the same:
-fuel injector
-iacv
-purge
-fan switch
-back up switch
alot more connectors are not listed
alot of rewire to be honest not worth it... i know u need it done but ure gonna have to get wiring diagrams from both obd1 and 2 and make sure it wire the same to strut tower...
Have to rewire:
Should be the same:
-fuel injector
-iacv
-purge
-fan switch
-back up switch
Thread titles MUST summarize the tech problem (be topic specific) so that members browsing titles can understand the problem without reading the post.
ooanth0nyoo123
10-23-2005 10:37 PM
