Timing mark question
Old 06-07-2012, 06:53 PM
shesinmyroom's Avatar
Default Timing mark question
Is this the tdc mark or is the other white line the tdc mark ?
Old 06-07-2012, 07:17 PM
Former User's Avatar
Default Re: Timing mark question
The pointer looks aligned with the TDC1 mark.
(your picture is too large)
Old 06-07-2012, 07:27 PM
Yes i realized it after it was uploaded.
but i only ask because if thats my tdc line my cams dont point straight up they both point 11 oclock instead of 12 if you know what i mean.
Old 06-07-2012, 07:33 PM
Your mechanical timing is off by a tooth or two.
Old 06-07-2012, 07:34 PM
but when i line it up to the other white line on the crank its tdc on the cams
Old 06-07-2012, 07:35 PM
Don't get distracted. The other mark is NOT the TDC1 mark. Set the timing correctly.
Old 06-07-2012, 07:40 PM
just making sure i 2nd guessed myself and i got curious.
so i set my crank at tdc slip off the belt and turn the cams to tdc without the belt on ?
Old 06-07-2012, 07:43 PM
Yep
Then turn the crank pulley a couple of revolutions counterclockwise to verify that the timing is still correct. Then tension the belt.
Old 06-07-2012, 07:45 PM
alright thank you very much. would this cause lack of power at times and to run rich ?
Old 06-07-2012, 07:50 PM
It would make the engine run like crap.
Old 06-07-2012, 07:51 PM
Really? well if my engine runs like crap its pretty fast
Old 06-07-2012, 08:07 PM
DavidCRV
08-26-2013 03:12 PM
WannaHonda
05-06-2004 10:12 AM
JONBLAZE55555
11-27-2003 12:46 PM
zccrx
12
04-23-2003 07:14 AM
Quick Reply: Timing mark question
