00 Civic - How do I remove the door molding clips without breaking them?
The black paint on my driver and passenger door molding (parts #1 and #3) is chipping and looks like ***, so I plan to remove and paint them this weekend. Five yellow plastic clips (part #9) secure each molding to the door.
Can somebody please tell me how to remove these plastic clips without breaking them?
Also, does anyone know of a good product for stripping off the old paint once I have the moldings removed?
The Grumpiest
Re: 00 Civic - How do I remove the door molding clips without breaking them?
I don't know how to get them off but I read where someone just used a razor blade on the paint prior to repainting. He kept them on the car and just masked everything off.
R.I.P. Mark
this should help give you the general idea
http://civic.hondafitjazz.com/A00/HT...361KBAT00.HTML
Are you able to see the pictures at the link?
I thought it might be easier to remove the molding and then repaint. But who knows, I may have to go this route.
Holly CR*P Ron dosent know something! My Faith in Honda tech just droped lol
I just masked mine off and used the razer blade trick came out good, just take your time when masking.Also heard something about using like 600 grit to ruff up the chrome stuff alittle and use some filler primer but I never did that.
Seagull Management
It's not paint, it's rubber. Use a razor blade to remove it, but leave the edges. Paint with duplicolor trim paint.
You're right. This was clearly evident after I removed the molding. The sun protected end of the molding that inserts into the door retained the original rubber coating. Thanks.
I posted a DIY thread for this project here:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/diy-door-glass-molding-removal-painting-96-00-civics-3063334/
You went through more hassle than what was needed to remove the trim. You do not need to pull the door card or glass. Those green tabs are actually not that brittle as people have been saying.
Here is how I did mine.
1. Technically you don't need to remove the door mirror, but it makes it a lot easier.
2. Grab the trim with your fingers by where the mirror was and pry it towards you.
3. Move down the trim till you get the whole thing off.
I did this and didn't break those tabs.
I tried it without removing the mirror and starting at the other end of the door, it worked but I took a chip out #2 of your original picture because part of the trim was behind the molding.
Just my $0.02 on making somebodies life a lot easier.
pjorge
08-28-2017 11:54 PM
tilhasbb
05-28-2007 08:17 PM
