92 EG Idle problem
92 EG Idle problem
Hey everyone, Im having an issue here.
I have a 1992 EG hatch with a 99' GSR swap.
I've just done a Skunk2 Intake Manifold swap along with a 68mm Omni TB.
I have all the plugs plugged into the right sensors, all lines everything connected.
I am using OEM gaskets for the manifold and the Omni gasket for the TB that came with.
I've adjust the new Omni TPS to the same v as my old TPS.
my issue is; when I start the car, its starts but Idles very low, maybe about 3-500, and the motor tends to shake.
Anyone have any idea what could be the problem? It would be much appreciated!
Re: 92 EG Idle problem
no CEL.
once i start the car with the OMNI TB, it idles low at start. but if I put the stock gsr TB back on with the stock TPS it idles just fine like it should
The Grumpiest
You answered your own question right here. You can't start putting all these air/fuel altering parts on the engine and not get it tuned to make use of and operate properly.
The Grumpiest
So you say. But... 1) we're not talking about your buddy's car and 2) how do you explain why it only runs correctly with the stock throttle body?
Maybe you should talk to your buddy and see where you're going wrong. But If the manifold was different, then it's not the "same" setup is it?
And aren't you supposed to install the OEM TPS on the Omni TB?
DanInOttawa
08-21-2014 06:59 PM
gsrboost737
10-25-2010 05:16 PM
